Ok, i got it!
this script (which is also updated on the github)
works like this
Get the storage information (total and available space) of a path.
Find the sizes of all external devices in terms of total storage capacity (not available because this will change)
Rank them in order of their total storage capacity
Check if the first option has space available to copy the new files
if not, choose the next option in terms of total storage
Copy all the files from the internal storage to the external storage
Move the files from the directory of "fresh" files to the internal "backedup" folder
if the internal storage gets too small, delete the internal "backedup" folder
This means it will choose a single external, copy files to it until it gets too full, and then start copying to another.
and it will hold onto backups as long as the internal storage allows.
I ran it through a bunch of tests with different memory sticks and it seems to be working good!
full code here!
thanks for the help @julianstirling
Backupper Script
This script is for folks collecting lots of data automatically that needs to get backed up at certain intervals
for instance saving a bunch of files to a folder, but then automatically copying them to larger external devices
This script first defines paths for the desktop, photos folder, and backup folder name. Then, it defines functions to:
Finally, the script checks if the photos folder exists and then finds the largest external storage. It compares the total space and available space on both the desktop and the external storage to determine if the external storage has enough space for the backup. If so, it creates a backup folder on the external storage and copies the photos. Otherwise, it informs the user about insufficient space.
Note:
This script assumes the user running the script has read and write permissions to the desktop and any external storage devices.
You might need to adjust the user name in desktop_path depending on your Raspberry Pi setup.
import os
import subprocess
import shutil
from pathlib import Path
# Define paths
desktop_path = Path(
"/home/pi/Desktop/Mothbox"
) # Assuming user is "pi" on your Raspberry Pi
photos_folder = desktop_path / "photos"
backedup_photos_folder = desktop_path / "photos_backedup"
backup_folder_name = "photos_backup"
internal_storage_minimum = 1
def get_storage_info(path):
Gets the total and available storage space of a path.
Args:
path: The path to the storage device.
Returns:
A tuple containing the total and available storage in bytes.
try:
stat = os.statvfs(path)
return stat.f_blocks * stat.f_bsize, stat.f_bavail * stat.f_bsize
except OSError:
return 0, 0 # Handle non-existent or inaccessible storages
def find_largest_external_storage():
Finds the largest external storage device connected to the Raspberry Pi.
Returns:
The path to the largest storage device or None if none is found.
largest_storage = None
largest_size = 0
for mount_point in os.listdir("/media/pi"):
path = Path(f"/media/pi/{mount_point}")
if path.is_dir():
total_size, available_size = get_storage_info(path)
print(path)
print(available_size)
if available_size > largest_size:
largest_storage = path
largest_size = available_size
if total_size > largest_size:
largest_size = total_size
print("Largest Storage: " + str(largest_storage))
print(largest_size)
return largest_storage
def rsync_photos_to_backup(source_dir, dest_dir):
if not os.path.exists(dest_dir):
os.makedirs(dest_dir)
# Build the rsync command with options for recursive copy, delete on source, and verbose output
# rsync_cmd = ["rsync", "-avz", "--delete", source_dir, dest_dir] # copies the whole folder, not just files inside
rsync_cmd = ["rsync", "-av", str(source_dir) + "/", dest_dir]
# Call rsync using subprocess
try:
process = subprocess.run(rsync_cmd, check=True)
except subprocess.CalledProcessError as err:
raise RuntimeError(f"Oh no! Mothbox couldn't backup your files!") from err
def rsync_copy_and_delete_files(source_dir, dest_dir):
This function uses rsync to copy files from source_dir to dest_dir and then deletes the originals from source_dir if successful.
Args:
source_dir: The source directory containing the files to copy.
dest_dir: The destination directory to copy the files to.
Raises:
subprocess.CalledProcessError: If the rsync command fails.
# If successful, iterate through copied files and delete them individually
if process.returncode == 0:
for root, _, files in os.walk(source_dir):
for filename in files:
source_file = os.path.join(root, filename)
dest_file = os.path.join(dest_dir, filename)
# Check if the file was successfully copied (exists in destination)
if os.path.isfile(dest_file):
try:
os.remove(source_file)
print(f"Deleted: {source_file}")
except OSError as e:
print(f"Error deleting {source_file}: {e}")
return process.returncode
# older way of just copying items in the folder
def copy_photos_to_backup(source_folder, target_folder):
Copies all files from the source folder to the target folder.
Args:
source_folder: The path to the source folder.
target_folder: The path to the target folder.
if not os.path.exists(target_folder):
os.makedirs(target_folder)
for filename in os.listdir(source_folder):
source_path = os.path.join(source_folder, filename)
target_path = os.path.join(target_folder, filename)
shutil.copy2(source_path, target_path) # Preserves file metadata
def delete_original_photos(source_folder):
Deletes all files from the source folder.
Args:
file_path = os.path.join(source_folder, filename)
try:
if os.path.isfile(file_path):
os.remove(file_path)
print(f"Error deleting file {file_path}: {e}")
if __name__ == "__main__":
# Check if "photos" folder exists
if not os.path.exists(photos_folder):
print("Photos folder not found, exiting.")
exit(1)
# Find largest external storage
# largest_storage = find_largest_external_storage()
# Get total and available space on desktop and external storage
desktop_total, desktop_available = get_storage_info(desktop_path)
# external_total,external_available = get_storage_info(largest_storage)
print("Desktop Total Storage: \t" + str(desktop_total))
print("Desktop Available Storage: \t" + str(desktop_available))
Finds storage capacity of all external drives and ranks them by size.
disks = {} # Dictionary to store disk name and capacity
# Check potential mount points for external drives (adjust based on your system)
if path.is_dir():
disks[path] = total_size, available_size
# Sort disks by capacity (descending)
# Check if any disks were found before sorting and printing
print("~~~sorting disks~~~~~~")
if disks:
sorted_disks = sorted(disks.items(), key=lambda item: item[1][0], reverse=True)
print("External Drives (Ranked by Total Size - Descending):")
for disk_name, capacity in sorted_disks:
print(
f"{disk_name}: total size {capacity[0]} GB - available size {capacity[1]} GB"
else:
print("No external drives found.")
print(
"stuff never worked out with this backup, your files are not properly backedup"
exit(1)
print("~~~sorted~~~~~~")
thingsworkedok = False
# this is the loop where we make stuff happen
# iterate through the disks, starting with the largest
# see if it has enough available space, if not, choose the next largest
total_available, external_available = capacity
# Check if external storage has more available space than desktop
if external_available > sum(
os.path.getsize(f) for f in photos_folder.iterdir() if f.is_file()
# Create backup folder on external storage
external_backup_folder = disk_name / backup_folder_name
try:
rsync_photos_to_backup(photos_folder, external_backup_folder)
# Proceed to the next step if successful
print(
f"Photos successfully copied to backup folder: {external_backup_folder}"
# since we were successful, move backed up images here!
rsync_copy_and_delete_files(photos_folder, backedup_photos_folder)
print(
f"Photos successfully copied to backed_up folder and deleted from fresh folder: {backedup_photos_folder}"
thingsworkedok = True
# After we backed up, we can check on our internal storage and see if we need to clean up
# Check if internal storage has less than X GB left
x = internal_storage_minimum
if desktop_available < x * 1024**3: # x GB in bytes
delete_original_photos(backedup_photos_folder)
print(
"Original photos deleted after being backed up due to low internal storage."
else:
print(
"More than "
+ str(x)
+ "GB remain so original files are also kept in internal storage after backing up to external storage"
print("we have finished backing up! yay!")
break
print(
"Error during backup, moving to next available storage if there is one!:",
err,
else:
print(
"This External storage doesn't have enough space for backup.\n Trying next available storage if there is one "
if thingsworkedok == False:
print(
else:
print("BACKUP COMPLETE")
