Replication Team: wireless color sensor
Hi again from replication team, I have done Mothbox DIY see it if you haven’t see it, check out this link:
I am testing things now, and I will give an update on that as soon as possible. So far, I have not caught any photos of insects, since Seattle has been cold and windy. When it is sunny and warm, the only bugs I see around are spiders, :slight_smile:
Anyhow, let’s start with this project. You can see it here:
I have been having a lot of issues with 3D printing. Some of them seem related to print setting adjustments, but there also seem to be some bigger issues happening sometimes.
I have included some photos here for your reference.
Anyhow, if you look at the link, you can see there are several parts to print. I checked the links, and that is where I found the first issue in this documentation.
As you can see, each part has a picture next to it, which I really liked. However, there is an issue here:
In the list of files to print, the first one is named “charging base.” When you download it and open it in the slicing software for the printer, you see the following geometry:
This seems to be the enclosure side, not the “charging base.”
Then there is a part named “base board,” but I do not see any 3D printing file for the base board here. It is supposed to look like what you see below:
I managed to print most of the parts after spending a lot of time, I am still missing couple parts:
