Thanks for setting this up! Looks great, the only downside compared to Eventbrite currently is more manual effort for the call organisers to remember to send the day in advance/hour in advance reminders rather than these going automatically but I see that is on the plugin developers roadmap.
Just to check - is there some way that people who register for events can add it to their calendars? I looked at the plugin thread and it was unclear but as you’ve been playing with it I thought you might know!
No problem, like I said before: since people are already signed up through Eventbrite I know it might be best to continue with that for now for the main calls. Having events built-in seemed useful anyway so I went ahead and set this up.
You can “add to calendar” through the event box menu but I haven’t tested that with Google calendar, which is probably what most people use.
I get an ICS file. In the Outlook web access we have to use for work, it is a 8-step process to get the web access to understand the ics file. For Google it is still 6 steps. You basically have to import it. It probably works better with a desktop client (insert another rant about services turning off SMTP).
The calendar may not be perfect for massive calls, but for things like the documentation call it great.
Does anyone know where the reminders from this plugin go/how they are displayed?
I messed up on the GOSH website meeting with @kaspar because somehow I failed to import the ics file properly to my Google calendar. That error is totally on me - I should have checked three weeks ago when I set the event up. However, I did set up reminders for one day and one hour before the event and I saw nothing. Where do they go?
