I’m in the process of building a Jubilee 3D-motion toolchanger from the kit available on Filastruder. My intention is to build a machine capable of working in the Science Jubilee ecosystem, seeing what we can learn about reproducing this system as we go.
I’m starting by focusing on getting the motion platform set up, but I’d like to eventually add a pipette and run a “Hello World” by having it “print” petri plate art from BioArtBot.
I’ll post updates here as I work through the process.
Frame Assembly
(I had a backlog of notes, so I’m posting several at once)
Again, it’s really nice how the guide walks you through how to square the frame instead of just saying to make it square. The kit even comes with machinists’ blocks to help with this.
The alignment process was a little bespoke and finicky, but after that it’s mostly just sliding T-nuts and brackets onto the extruded aluminum for ~90 minutes.
The step-by-step guide is nice, but I think it would have been clearer to me if there was a short header at the beginning explaining what the end goal was. The squaring process involves a lot of connecting and disconnecting parts, which was a little confusing
This whole part took about 2.5 hours
Pulley Assemblies
- This page would be clearer if I had any idea which pulleys came in the kit. I followed the Gates page because the pulleys fit better on the shoulder screw that way. Plus the aspect ratio looked more correct in the Gates page
This took me about 40 minutes. Very clear documentation and the design is intuitive, excepting the one note above. Plus they’re very aesthetic!
sick documentation so far!
