Open Hardware Kinematic Challenge: The CMTS Project (Circular Mass Transfer System)
Hello everyone,
I am issuing an open Kinematic & Mechanical Challenge to the global community of machinists, engineers, and physicists here at GOSH.
I have designed a mechanism that challenges standard textbook assumptions regarding mechanical dead centers and continuous torque asymmetry. Rather than debating the theory, I am releasing the complete workshop blueprints today under an open-source license so the community can audit, replicate, and test the geometry itself.
Below are the technical specifications, project parameters, and secure direct download links for the workshop notebooks (available in English, French, and Spanish). Let’s review the blueprints and discuss!
:stop_sign: Essential Prerequisite: Kinematics vs. Thermodynamics
To prevent generic and irrelevant objections: this project is strictly positioned within the parameters of KINEMATICS and SOLID-BODY STATICS.
Historical eccentric or gravity wheels failed in practice because their symmetrical internal paths systematically generated a net torque of exactly 0 Nm at the hub, causing them to stall under friction. The CMTS architecture addresses this specific geometric deadlock, evaluating the raw physical torque profiles at the 3 o’clock and 9 o’clock coordinates. It is an exploration of asymmetric lever arm geometry, not a thermal conversion process.
:gear: The Kinematic Challenge: Breaking the 6 and 12 O’Clock Dead Center
The Circular Mass Transfer System (CMTS) — Système de Transfert Circulaire de Masse (STCM) — is an open mechanical technology designed in Montreal, Canada.
The core objective is to generate a continuous asymmetrical torque in a central hub using moving masses governed by a strict orbital constraint principle along perfect eccentric trajectories. By utilizing these dual offset paths, the geometry is specifically engineered to bypass the classic gravitational dead center encountered at the 6 o’clock and 12 o’clock positions.
The raw geometry of these workshop prints is designed to showcase this feasibility. The challenge is now in your hands: look at the tracé d’atelier, audit the constraints, and verify the path.
:green_circle: Workshop Technical Specifications
To prevent structural deflection and ensure operational rigidity, the layout requires tight machining tolerances and rigid components:
  • Initial Action Radius: 7.0 cm (extensible up to 12.0 cm for scaling).
  • Distance Between Masses (Drawing No. 6): 6.5 cm center-to-center (3.25 cm rigid pivot arms).
  • Dynamic Guidance Displacement (Drawing No. 7): 4.2 cm center-to-center (two 2.1 cm sections).
  • Shaft Architecture: Double independent central axis arrangement side-by-side (Profile, front, and top views).
  • Kinematic Linkage: Toothed sprockets connected by a synchronous chain or belt to physically lock the geometric path.
  • Materials: Rigid machined steel is mandatory. Acrylic, plexiglass, or flexible plastics are strictly prohibited (as they flex under load and seize the central hub).
:balance_scale: Legal Status & License
  • Public Domain Donation: Sworn affidavit signed in February 2026 before Commissioner Robert Asselin (Seal No. 202 319) in Montreal, Quebec, permanently securing authorship under the original project name “Circular Crane”.
  • License: Creative Commons Attribution-NonCommercial-ShareAlike (CC BY-NC-SA 4.0).
:inbox_tray: DIRECT DOWNLOAD LINKS & OFFICIAL REGISTRIES
:speech_balloon: How to Participate in the Challenge
  1. The Blueprint Audit: Download the technical notebooks and mathematically verify the 2.1 cm pivoting offset and the 4.2 cm center-to-center guidance displacement against the rigid arms.
  2. Prototyping & Workshop Testing: For members with an active lathe, mill, or CNC in their workshop, the tolerances are fully optimized for direct machine bed testing. Grab your rulers, machine the components in high-rigidity steel, and verify the physical path.
Feel free to post your mathematical critiques, workshop photos, or physical testing results directly in this thread, or reach out privately for technical validation and collaborative engineering at: Benoitcc58@proton.me
**MISE À JOUR IMPORTANTE : Problème d’affichage résolu & Versions multilingues en ligne ! / IMPORTANT UPDATE: Display bug fixed & Multilingual versions live!** **FR :** Bonjour à tous, Je vous annonce que le problème technique lié au recadrage automatique d’Archive.org (qui tronquait anormalement la marge droite de mes croquis) est désormais **entièrement résolu**. Les coordonnées d’axes, les dessins et les liaisons cinématiques indispensables situés sur les bords droits sont enfin 100 % visibles et exploitables. Pour télécharger gratuitement le cahier technique complet de 66 pages d’atelier sans aucun bug d’affichage, merci d’utiliser uniquement ces nouveaux liens officiels : * :globe_showing_europe_africa: **Internet Archive (Téléchargements PDF direct) :** * **Français (Cahier Technique) :** Internet Archive: Digital Library of Free & Borrowable Texts, Movies, Music & Wayback Machine * **English (Global Kinematic Challenge 2026) :** Global Kinematc 2026 Benoit Collin : Benoit Collin : Free Download, Borrow, and Streaming : Internet Archive * **Español (Desafío Cinemático Mundial 2026) :**Desafío Cinemático Mundial 2026 Benoit Collin.pdf : Benoit Collin : Free Download, Borrow, and Streaming : Internet Archive * :hammer_and_wrench: **Forges de Développement :** * **GitHub Repository :** circular-mass-transfer-system-cmts/stcm-systeme-defi-cinematique-benoit-collin.pdf.pdf at main · BenoitCollin/circular-mass-transfer-system-cmts · GitHub * **Codeberg Repository :** BenoitCollin/circular-mass-transfer-system-cmts: Official engineering blueprints and workshop manuals for the Circular Mass Transfer System (CMTS). Designed in Montreal, Canada, to evaluate torque profiles and dead-center management. Released into the public domain (CC BY-NC-SA 4.0). - Codeberg.org — **EN:** Hello everyone, I am glad to inform you that the Archive.org auto-cropping bug (which truncated the right margin of my technical drawings) is now **fully resolved**. All original axis coordinates, modules, and crucial kinematic linkages on the right edge are 100% visible and ready for workshop evaluation. This updated release introduces the complete 66-page dossier available across independent repositories for French, English (**Global Kinematic Challenge 2026**), and Spanish (**Desafío Cinemático Mundial 2026**). Please use the verified links above to access the clean documents. Merci pour votre patience, place à la mécanique d’atelier ! / Thank you for your patience, let’s bring it to the machine shop! Benoît Collin (Montréal)
