OHM cohort 2 call for participation!
The call for applications for the second cohort of the Open Hardware Makers program is now open!
Sponsored by Code for Science & Society event fund, this cohort is dedicated to Open Science Hardware!
If you would like to learn and implement best practices on Open Source Hardware for your current project, this is for you.
OHM is a mentorship program for open source hardware projects and their developers. In it, you will learn the best practices in open hardware that will prepare you to build a reusable, inclusive and sustainable project. All projects that participate in OHM are expected to publish their documentation, hardware and software under open licences.
Why you should apply:
  • You will learn best practices in open hardware that will make your project more inclusive for users and collaborators
  • You will get in contact with experienced people in the open hardware community
  • You will meet and share lessons with fellow open hardware developers
  • This cohort has been supported by Code for Science & Society, and a small stipend will be available for selected projects
The program runs over 16 weeks (from October 03rd 2022 to February 19th 2023 - there is a small break from mid December to mid January).
Accepted participants will work through the curriculum supported by a dedicated mentor, while engaging with the wider OHM community (experts, fellow participants, other mentors and organisers). We expect mentees to dedicate ~5 hours per week to successfully go through the program and apply their learnings to their projects.
More details about the program and the role of mentees can be found here.
Eligibility
  • You have an open source hardware project with information already publicly available, on any online platform.
  • Your open hardware project can be aimed to any field/community, considering our community guidelines Community guidelines
  • Your project needs to fall within the GOSH definition of open science hardware:
Important dates:
  • Application are open and close on September 2nd 2022
  • Program starts on October 3rd 2022 and ends on February 19th 2023
  • Application link
If you have any questions about the application process, please write to OHM at ohwmakers@gmail.com
