Community Engagement - Experimenting with RSS Polling Between OH Communities
This is a good point
We can have a shared agreement for the broadcast/cross-forum posts. This could set out things like
  • Conduct - If all forums have a broadly aligned codes of conduct and are moderated then this should be enough. If any forum is not well moderated they might need to be dropped from from the list. There would need to be a clear point of contact for each forum to flag any problems to. I think as the polled post is posted here by system a GOSH moderator could remove a post that violated the code of conduct.
  • Significance/rate of cross forum posts: One forum should not be flooding this channel with loads of stuff. This could be as simple as.
    Cross-forum posts should be topics that are of wide interest across the open hardware community. On average no more than 2-3 a month (with no strict limit if lots of exciting news happens to come at once!)
