The call for applications for the first cohort of the Open Hardware Makers program is now open!
If you would like to learn and implement best practices on Open Source Hardware for your current project, this is for you.
OHM is a mentorship program for open source hardware projects and their developers. In it, you will learn the best practices in open hardware that will prepare you to build a reusable, inclusive and sustainable project. All projects that participate in OHM are expected to publish their documentation, hardware and software under open licences.
The program runs over 16 weeks (from March 14th 2022 to July 1st 2022). Accepted participants will work through the curriculum supported by a dedicated mentor, while engaging with the wider OHM community (experts, fellow participants, other mentors and organisers). We expect mentees to dedicate ~5 hours per week to successfully go through the program and apply their learnings to their projects. More details about the program and the role of menteescan be found here.
Eligibility
You lead or are part of a team working on an open source hardware project with information already publicly available, on any online platform.
Your open hardware project can be aimed to any field/community, considering our community guidelines Community guidelines
Important dates:
Application opens on January 24th and close on Feb 21th 2022
Program starts on March 14th 2022 and ends on July 1st 2022
Application link: https://forms.gle/Z4kS7bTbvhXnam5v9
If you have any questions about the application process, please write to OHM at ohwmakers@gmail.com
