definitely a n00b question ahead, be warned –
how difficult would it be for a neophyte like me to build a relatively simple bioprinter that can print mycelium substrate? Should be:
- low cost
- scavenged parts preferably
- sturdy
my background: not clumsy, can use the right tool for the right job, but can also f*&# up easily so would want to walk before trying to run
claaaasiiic from the hackteria wiki, developed in HLab2013, bangalore:
https://www.hackteria.org/wiki/Poor_Man's_BioPrinter
urs and others worked on this during HLab2011:
https://www.hackteria.org/wiki/DIY_Micro_Dispensing_and_Bio_Printing
low-cost, hacked old cd-drives.
but also pretty easy to use a cheap 3d printer and add a syringe.
good luck!!
marc
ahja,
i hope you talked to nieves at BioFabbing.
http://openbioprinting.org/
m
I think the result of that Hackteria exercise is documented at http://www.instructables.com/id/DIY-BioPrinter/
That was my first step in this quest, second step was starting this thread. That does sound like a great project. I’d like to study a few alternatives as well. I am also thinking this is something that could use the automated syringe pump thingy that Ali Afshar (Hackscience) showed off in Santiago.
oh good one Marc. Thanks. I will ping her.
Hi @punkish,
There is also a cool recent extruder design from the GOSH community, that can be mounted on any 3d printer or CNC stage: http://irnas.eu/vitaprint
It allows temperature control of the liquid, which is really important for good results in bioprinting. Depends how low-cost DIY you want to go
Cheers,
Tobey
Thanks Tobey, will check it out.
